Thread: Tile Cleaner
    Scottsdale, Arizona
    Default Tile Cleaner
    Hello, going to drain the pool when the season ends and I'd like to clean my tile when i do. It has a slight chalky built up right at the water line but nothing real serious.Id just like to make it shine again.
    What products are recommended?
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    Jul 2010
    Largo, Florida
    Default Re: Tile Cleaner
    I've had good success cleaning my water line tiles with suncoast "tile and liner cleaner". It's basically an acidic gel that can be thickened by adding a little muriatic acid. A little bit of that with a scrub pad does a fine job. I'm sure there's other brands of similar product.
    There's another old thread on this topic here: http://www.poolforum.com/pf2/showthr...-tile-cleaning
