Results 1 to 10 of 12
Thread: Vacuuming
    Philly Burbs
    Default Re: Vacuuming
    I dont understand how you vacuum to waste. Wouldn't you use too much water? By the time I got done I would probably be almost below the skimmer line unless I'm missing something here.
    Downingtown, PA
    You only want to vacuum to waste if you are cleaning some nasty stuff, like a layer a couple inches deep worth of leaves and gunk off the bottom. You would not want to do routine vacuuming to waste because of the water loss.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    A pretty large number of us use suction side cleaners without strainers. Even so, My filter hasn't needed backwashing for over two months. I think vaccuuming to waste is helpful for short term problems like major algae clean up or plant debris on the bottom. If you don't have that kind of problem then you don't need to vaccuum to waste.
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
    Houston.
    My Polaris 280 runs daily for 2.5 hours. I use the sand and silt bags so it picks up tons of dust. I also rotate between two bags to allow easier cleaning of a dry bag versus trying to get wet sand out of a wet bag.
    Anyway, with running my 280, my floor bottom looks clean, so I'm never vacuuming. Should I be? My builder said with the cleaner, I'll probably never need to vacuum. He told me incorrect information before, so should I be vacuuming for some reason?
    In fact, I like the idea that the 280 puts the dirt in the bag that I then empty in the trash versus the vacuum that would put the dirt in the filter.
    Thanks,
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    You don't need to vaccuum unless there is something on the bottom to vaccuum.
    I was just trying to make the point that those of us with kreepy's and baracudas and such constantly vaccuum to filter. Point being that vaccuuming to waste is only necessary for special circumstances.
    Rangeball asked if "you always vacuum to waste" and I just meant to say "no."
    IL.
    My initial concern was organics being contained in the filter and consuming chlorine versus getting them out of the pool and leaving the bleach to do it's job.
    However, the past several days the birds seem to preferentially want to crap in my pool. I've been leaving the vac out ready to go, and am vacuuming daily, sometimes more. The crap is going into the filter (what the pump basket doesn't catch) and my FC has been holding fine, so I quit worrying about this
    Houston.
    Thanks sailork. That makes sense.
    Robert
    Luling, Louisiana
    Question Re: Vacuuming
    Does anybody on this forum know about the Pool Buster Max? This is adverised as a rechargeable pool vaccum that is made by Water Tech. The unit sells for $199 and is attached to your pole. The company claims that you can vaccum without wasting water. Does anybody have one and can anybody share about this product?
    Thanks,
    TheNewPoolGuy
  1. Help! I'm sick of vacuuming.
    By shadowman in forum Pool Equipment & Operations
    Last Post: 06-14-2007, 12:41 AM
  2. vacuuming
    By kecsmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-20-2007, 12:37 AM
  3. Clog after vacuuming
    By vikes in forum Pool Equipment & Operations
    Last Post: 10-01-2006, 01:49 AM
  4. High CL & Vacuuming
    By fuelman in forum Dealing with Algae & Slime
    Last Post: 09-19-2006, 12:08 AM
  5. Vacuuming problem...
    By lindamom25 in forum Dealing with Algae & Slime
    Last Post: 04-02-2006, 12:27 AM
