Thread: How to figure run time for 2-speed pump?
    Dec 2005
    Bakersfield, CA, USA.
    Default Re: How to figure run time for 2-speed pump?
    If my 1.5HP pump has the same flow rate as yours in both speeds (this is just a guess til I find out) than I am changing the water over between 2 and 3 times per day. Currently the temperatures are in the low nineties and the pool holds between 80 and 86 degrees during the day. Does this rate of turnover sound like overkill?
    Green Bay, WI
    Sort of overkill, but if it keeps you pool clear then it's ok. I would just run it in low for a longer time becasue it is cheaper and most filters work better at a lower flow rate then a higher one. Sounds like 12 hours on low should do the trick for you.
    Mesa, AZ
    There are a lot of things to consider. Do you have any features that require the pump to be on high speed to operate properly? Automatic cleaner or In-floor cleaning? If not, can you get the circulation you want without running on high speed at all? Maybe you only need to run on high speed when you want to quickly skim some debris from the surface?
    I have a 2 speed pump, and my pool builder sucessfully sold me on the benefits of 24 hour-a-day circulation. Public pools are required by law to have 24 hour circulation. I run on high speed a few hours in the AM when I am likely to be adding acid. A few hours in the middle of the day to increase the flow through my redneck solar in the peak of the day, and a few hours in the afternoon when we're most likely to be in the pool and might want to turn on the fountain or sheer descent. The rest the time I run in low speed. My water is continuously filtered and sanitized by the SWG which I run at a much lower percetage. I know my circulation is overkill, but it only costs me a few extra $$ a month and my pool always looks great
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. Bought a new AG pool; now need to figure out pump and fitler
    By K9SwimCoach in forum Pool Equipment & Operations
    Last Post: 06-30-2012, 08:19 PM
  3. Variable Speed pump "sizing" and how do I figure it out
    By kelemvor in forum Pool Equipment & Operations
    Last Post: 05-03-2012, 12:01 PM
  4. 2 Speed Century Pump Motor is now only 1 speed
    By TelexBill in forum In-Ground Pool Construction and Repair
    Last Post: 10-14-2011, 10:40 PM
  5. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
