Thread: CYA and FC question
    Default Re: CYA and FC question
    It is not abnormal for a pool to lose 3 ppm over a day time--but whether it's because your CYA is too low or because you have something in the water using up your chorine is anybody's guess. I would try shocking it for a day or so, then let it drift back down, and see if the consumption stays the same. If it was matter consuming it, then you should be able to see a chlorine residual. If the consumption is the same, then I'd try raising the CYA.
    Caledon, Ontario, Canada.
    You really need to get a better test kit. Walmart has one for about $ 15.
    This kit will test for free chlorine and total chlorine. When you know both of these numbers you subract free from total and it tells you what you "combined chlorine" level is.
    Combined chlorine is chlorine that has been partially used oxodizing stuff in the water. The stuff could be just leaves and debris, or kids pee and fecal matter. The fecal matter is where there dangerous infections come from. This is why you need to know the combined chlorine ( shorthand CC ).
    If you discover you have a CC level of 0.5 or more then there is "stuff" in the pool that needs to be oxodized to sanitize the pool. If you keep adding regular doses of chlorine, you will not attack the CC. You need to raise the level of chlorine to shock levels to burn it out.
    What the shock level is in your pool will depend on the CYA level ... another reason you need a better test kit. See the article at the very top of this section "best guest CYA" That will give you more info.
  1. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
