Page 16 of 16 FirstFirst ... 6 14 15 16
Results 151 to 152 of 152
Thread: Bromine Chemistry Question
  1. #151
    Virginia
    Default Re: Bromine Chemisty Question
    Again, using a PO4 remover ONLY has value if you take the PO4 level down to a measured 125 ppb (0.125 ppm) level OR LESS. Simply lowering the PO4 from 2,000 ppb to 500 ppb is probably useless. Also low PO4 levels only make it EASIER to kill resistant algae; low PO4 does not kill algae by itself.
    If you have been successfully maintaining a clear pool on opening without messing with a PO4 remover, using one probably serves no purpose.
    Thanks for the clarification.
  2. #152
    Jul 2013
    Northern Illinois
    Hey all! Thanks again SO MUCH for all the help you have given me. The pool has been so easy to maintain this year!
    I have a question for you. So far this summer I have been able to use rain to fill but now I need to use my well water. It does contain iron and some kind of iron-bacteria that is best observed as a gelatinous, light-orange growth in our toilet tanks.
    I usually attach my hose to an inside spigot which has softened water and attach a Hydopure MetalTrap filter to the end of the hose. The softened water doesn't last the whole fill and if time is not an issue, I will add a half hour per day. Otherwise I just go for it.
    I am thinking of adding the well water and then switching my sanitizer from bleach to cal-hypo added to my skimmer in the hopes that the iron will catch on the calcium left on the filter. I currently am metal-free.
    What do you think?
  1. Chemistry question
    By dansdad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2013, 10:25 PM
  2. Bromine pool - no detectable bromine.
    By ptrdvs44 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2012, 05:58 PM
  3. CYA in a Bromine Pool
    By chem geek in forum The China Shop
    Last Post: 07-21-2010, 08:28 PM
  4. Bromine question
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-16-2006, 10:02 AM
  5. High bromine
    By amantero in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2006, 04:29 PM
