Perfect! Just keep tabs on your pH ( between 7.2-7.6), chlorine (for right now about 3 ppm, when the CYA gets higher you will have to raise the chlorine levels to compensate), and your CYA (when it gets over about 60 ppm you should stop using the tabs and just use bleach to chorinate or you will have to drain and refill once it gest above about 80 ppm)
ENJOY THE POOL AND HAPPY SWIMMING!!!!! YOU DID IT!!!!!!!![]()
