Thread: 15x48 pool pump help
    Jun 2013
    W Virginia
    Default Re: 15x48 pool pump help
    Jul 2012
    Mexico, Missouri
    Check my signature. You are buying the same pump and filter I've had for about a year. Works great on my 15' x 48" Intex.
    If your pool has the small hose clamp style fittings, Check with amazon to see if the large pool fittings and valves are included along with the 1-1/2" hoses. You will need them, as the 1-1/4" (hose clamp style) hoses will not work with this pump.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
