Re: Shopping for an above ground pool (and learning all I can from this forum!)
For an inground pool look do you mean bury the entire pool n the ground of build a deck completely around the above ground pool?
Probably the route of building a deck around the pool to somewhat hide that it's actually above ground. (I figure if I connect the pool deck to the deck leading out of the house, it'll look a bit more integrated than just sitting alone by itself. While I've seen several pools that claim they can be buried, it sounds like several people on the forums don't really recommend it - and that seems like a bigger risk if something bad happens. (Not that anything bad would ever happen, right?!)
