My pump has developed a very small leak. It appears to be coming from the shaft seal. I was able to disassemble the unit to the point where I need to remove the impeller from th shaft. Can someone describe the process or the tool(s) required to do this. I was thinking about a gear puller but thought I would ask here first.
Filter is a Sta rite system 3PLM 100 with a 1 hp A.O. Smith pump model # s 48b74ao3 . It is a side discharge if that matters
Mark
