Results 1 to 10 of 17
Thread: Pool-O-Morphosis
    Visalia, CA USA
    Default Pool-O-Morphosis
    Here's a few pics of my swamp project.
    Oh... don't think I can post pics. Do we have to external link?
    Visalia, CA USA
    Default Re: Pool-O-Morphosis
    The beginning...
    Removing the cover...
    Hey look... dirt!
    And deep muck!
    I think we're going to need a bigger sump pump!
    Getting cleaner by the day.... only another week or three until WATER!
    Visalia, CA USA
    My sump pump took it down to about 12-16 inches. The concentrated muck was just too thick for the pump. It reminded me of tar in color and consistency. I'll leave the rest up to the imagination. I got in there with a shovel and a 5 gallon bucket to get the rest out.
    The plaster is badly stained, but I'm going to fill it up first and confirm how the rest of the mechanics are working before determining just how far to go. Before filling it up I need to replace 27 contiguous tiles that were improperly installed. They used ceramic tile, there were huge voids behind the tiles, and they used a rubbery adhesive to hold them on. There's already 3 different tile designs around the pool, so looks aren't what I'm worried about yet. More pictures as I progress.
    Watermom is offline Super Moderator Quark Inspector Watermom 4 stars Watermom 4 stars Watermom 4 stars Watermom 4 stars Watermom 4 stars Watermom 4 stars
    Jul 2013
    Mansfield, TX
    Good looking progress, can't wait to see the renewed pool.
    Visalia, CA USA
    Getting closer. The new light came today. Bought it from a Utah company at http://www.sunplay.com for $199.95, which was about $20 cheaper than the best price on Amazon, and $100 cheaper than any brick and mortar stores around here. Free shipping and no California sales tax (another $19 additional), which we've started to have to pay when dealing with Amazon. It's a Pentair Amerlite 300 Watt Pool Light 78928500 - 100 Foot Cord.
    Now I need to get a pile of chemicals for the big day. I did some tap water testing and found it to be MUCH softer than I had anticipated.
    PH 7.8
    CH 40
    TA <30
    I'm shocked that the CH was that low. I'm hoping the test kit I just bought will be accurate enough to get things up and running until I can afford a better one. It's a Wal-Mart HTH 6-way.
    I'm estimating that the pool holds about 25,000 gallons, and is in full sun. Anyone want to make a fair guess as to what and how much I'll be wanting to have on hand when I fill er up?
    Visalia, CA USA
    Two more photos from this week....
    First is the tile before grout...
    Then looking up at the stretch of new tile. Yes, that is actually 4 different tiles in a row on the right. Like I said... we're on a shoestring budget and if it holds water it stays.
    I'll get the light installed tomorrow. The plaster is hideous looking, but blasting it with 2400 psi water had no effect. I decided to leave it like that and get some water in there so that I can evaluate the other systems... particularly the plumbing.
    A few years from now I may redo the tile and plaster from scratch, but for now it is what it is.
    Visalia, CA USA
    Some more photos through to the finish...
    Visalia, CA USA
    BTW, as you can see there's a concrete curb that goes around the Cooldeck. It used to have crushed volcanic rock. I'm looking for ideas as to what to place in there. I'm leaning towards decomposed granite base with a flat stone mosaic laid on top of it. Any ideas as to what would be good to put in there?
    Jun 2013
    Central Florida
    Cool! It looks like a kind of french drain. If the granite you are considering compacts real hard, it won't drain anymore. If you want it to drain, maybe something like pea gravel underneath would work. I'd hate to leave any of that exposed, though, it would just end up in the pool. If overflow ends up in the grass it's probably no big deal unless you make a mud pit.
    In-ground gunite 16 x 30 13,000 gal. Full screen enclosure. 120 sq ft. Filter cartridge, 1-1/2 HP pump. Master Pools In-floor cleaner. Taylor K-2006.
