Thread: Cement Staining
    Default Cement Staining
    Parts of the cement border around my pool are stained with some type of black mold. I tried Tilex and I tried a little acid. Neither removed the stains completely. Does anyone have any suggestions? Thanks.
    markphin is offline Registered+ Thread Analyst markphin 1 star
    Default
    Try a powerwasher. It can do wonders.
    Mandeville, LA, USA.
    Default
    Sounds like it may be mildew. Bleach, cut with water at 3 or 4 to one, will normally kill it.
    Default Both Good Ideas
    Thanks. Those are both good ideas. I'm having my house pressure cleaned in about a week. I'll ask them to try pressure cleaning the cement. But, I'll try the bleach also.
  1. Pool cement crack isues
    By gibbyhome in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2012, 08:27 PM
  2. Ug pool- cement? -is a liner really necessary?
    By maclelld51 in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2011, 07:48 AM
  3. Cement vs Fiberglass Pool
    By jsack22 in forum In-Ground Pool Construction and Repair
    Last Post: 04-05-2011, 12:37 PM
  4. PVC Cement
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 02-09-2009, 08:45 AM
  5. Cement and sand bottom
    By fulkerl in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2006, 10:34 AM
