Thread: Does a sand filter pump use chemicals?
    Jun 2013
    USA
    Default Does a sand filter pump use chemicals?
    We are exploring options and my husband bought a sand filter pump but we don't see anything about using chemicals?
    BigDave's Avatar
    Default Re: Does a sand filter pump use chemicals?
    You need chlorine to keep any pool sanitized regardless of pump / filter type.
    Jun 2013
    USA
    So where do I start no directions with anything
    Some questions for you:
    -- What kind of pool do you have and what is the volume?
    -- How big is your pump?
    -- Do you have a test kit and if so, what kind?
    -- Is the pool already filled?
    -- What is the source of your fill water?
    -- What all have you added to the pool -- meaning ingredients and not just product names or 'shock.'
    Read a lot here on the forum, especially the stickied thread at the top of the subforums. Also, read on our sister website www.poolsolutions.com
    Jun 2013
    USA
    Intex ultra frame 18 x 52
    It is the intex 14 hp sand filter pump holds 55 pounds of sand
    Will be buying a real test kit only have the cheap strips
    Pool is filled and we ran pump for a bit just finished filling today
    Fill water is rural water have not added anything yet.
    Jun 2013
    toronto, canada
    bring your stabilzer to 30-40, (buy from walmart) use bleach/liquid chlorine to use to chlorinate (bring it up the amount suggested by ben in his best guess chart), bring you PH to 7.4-7.6 range and you'll be good! I use muriatic acid (PH down) borax (PH up)- (or aerate), liquid chlorine (more cost effective in my area then bleach). and stabilizer from walmart - only put that in once a year.
    your pool will be shiny clean!
  1. Intex Above ground, G.A.M.E Sand Filter, BioGuard Stingy Sticks, and other chemicals
    By kristen in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2011, 04:22 PM
  2. Chemicals to clean the sand filter?
    By sartail in forum Pool Equipment & Operations
    Last Post: 04-24-2007, 03:29 PM
  3. DE in Sand Filter,2spd pump
    By Davenj in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 05:02 PM
  4. Sand Filter & Pump Motor
    By ridgelljk in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 12:28 PM
  5. What size sand filter and pump?
    By sisie5 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-25-2006, 10:34 AM
