Thread: Help - buying used AG Pool
    Jun 2013
    Kentucky, USA
    Question Help - buying used AG Pool
    We are currently looking at buying a used AG pool from a friend.
    The pool is 9 yrs old, 30 ft round, very well taken care of, w/ original liner.
    We as going to pay a small amount but that is worth the deck, chemicals , and odds and ends that are coming with it.
    What is ur advice? There is a blemish under the outside wall under the hose that goes for the jet, but it seems structurally sound. The head to the filter is new, but I dot know he brand. I have not seen it with the liner off, so I don't know how the rail looks or the inside of the walls.
    If I move it, is a new liner a Must? What else am I not realizing could be a potential issue?
    Thanks for any help or input
    BigDave's Avatar
    Default Re: Help - buying used AG Pool
    9 years, the liner's probably not going to want to stretch back into the pool after it's removed and rebuilt; you should count on getting a new one.
    Do you think the blemish is rust under the finish - that could be trouble.
    You may have trouble locating replacements for buried parts that don't pass muster - If you know where the pool came from, perhaps you can determine the availability of spares before you start.
    The expense of installation may exceed the cost of a pool.
  1. Replies: 0
    Last Post: 01-01-2013, 05:05 PM
  2. Need advice on buying used AG pool
    By msedc in forum Above-Ground Pool Construction & Repair
    Last Post: 08-09-2012, 08:46 PM
  3. Buying a house with a pool; what should I ask?
    By veghead in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-13-2012, 01:55 AM
  4. Buying a home with a pool
    By jeffyzf in forum In-Ground Pool Construction and Repair
    Last Post: 02-12-2012, 07:45 PM
  5. buying new pool
    By happyjack in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2010, 04:26 PM
