Results 1 to 10 of 12
Thread: told to post numbers and help will come!!
    Area Man is offline ** No working email address ** Area Man 0
    OK.
    Default Re: told to post numbers and help will come!!
    You might try 1/4 of a box of borax, wait a day, test, and repeat until your pH is where you want it.
    timmie is offline Registered+ Thread Analyst timmie 0
    manitoba, canada
    hi, thanks about the Borax. I added it tonight. My ph is between 7.2 and 7.5. I will get the water tested at the pool store to make sure I am on track.
  1. New pool owner - told to drain pool - Need advice PLEASE!
    By kenfromtracy in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-22-2012, 09:54 PM
  2. How are my numbers?
    By SandyDittmer in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-04-2009, 05:14 PM
  3. Need help, we were told we need a new pump
    By delta410 in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 07:00 PM
  4. My first post and first test numbers
    By sharknj in forum DPD-FAS based testing
    Last Post: 06-04-2006, 03:26 PM
  5. 96% bleach - The pool store told me :)
    By cleancloths in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2006, 11:03 AM
