You are correct.....I missed the part about the 24 volts.
It sounds like you have things under control....(pun intended)![]()
[QUOTE=rrands]MrDuffin:
I don't think the idea w/ the 3 way light switch will work - for the x10 to work, it has to be on my home wiring - the voltage I am trying to switch is 24v AC, so if I hook that up as you mentioned, the x10 transmitter has no way to talk to the switch to turn it on/off. Does that sound right, or am I missing something?
