Results 1 to 10 of 13
Thread: Advice on Variable Speed Pumps for Spa
    BigDave's Avatar
    Default Re: Advice on Variable Speed Pumps Please
    One note: I purchased the SVRS version of the Hayward ECOStar and had to ask Hayward - very nicely - for a downgrade to the non-SVRS controller because the SVRS pump saw priming my roof mounted solar panels as an entrapment event and shutdown.
    Sep 2011
    Big Dave, I too have roof mounted solar. I am having trouble understanding how that could effect the controller in a variable speed pump, can you expand on that? Thanks.
    BigDave's Avatar
    My solar system has a valve (vacuum check?) that lets air in the system to allow the panels and piping to drain back down when not in use. Because of this the panels need to primed each time the controller moves the diverter valve sending the pool water to the panels. While the pipes and panels are filling, the flow rate slows significantly because the pump is overcoming the static head as well as the dynamic head in the piping system. Once the pipes, panels, and return lines are filled, the static head is equalized by the weight of the water in the pipes coming down from the roof.
    The SVRS (Safety Vacuum Release System) function saw this low flow to be an entrapment event (somebody stuck in the drain) and shut the pump down to release the suction.
    Sep 2011
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. Variable-speed pumps: US Dept of Energy guide (May 2012)
    Last Post: 07-24-2012, 05:04 PM
  3. UGH! Variable speed? Which one?
    By awhite6455 in forum Pool Equipment & Operations
    Last Post: 06-09-2012, 09:01 PM
  4. I;m looking for information on variable speed pool pumps
    By kearneypd in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 08:54 PM
  5. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
