Thread: Light question
    May 2013
    Northwest Indiana
    Default Light question
    The light in my pool is functional, but it does not act as expected. There are 2 switches labeled "light" and "color". When the light is on, the color switch turns on a motor that rotateds colored lenses (blue, green, purple and clear). The oddity is when turning on the light... When I flip the switch, nothing happens for a few seconds, then the light flickers. The frequency of flickering increases gradually for the next 30 seconds or so until the light begins to glow steadily. Once that happens, it starts dim and gradually gets brighter over the next few minutes. This is typical of a fluorescent bulb or murcury-vapor, but I cannot find anything on the web (or this forum) about pool lights using either of those types of lighting. I cannot get in the pool yet, so I don't know who manufactured the light. Everything else on the pool is Hayward (about 10 years old) so it is possible the light is the same.
    While the light works, the legth of time it takes to "ignite" suggests it may need replacement soon. I would like to research that ahead of time, but I can't figure out where to start. Any ideas?
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Jun 2013
    Central Florida
    Default Re: Light question
    Depends on the voltage source 120 volt or low voltage. Low voltage lights have a transformer that might be breaking down. A 120 volt source may be arcing at a connection somewhere until it finally "makes". If you have a junction box near the light you may be able to monitor the voltage there. Fluctuations may not occur if the power source does not have a load on it. Some LED lights have internal power supplies. This may be going bad. Maybe the switch is arcing.
    In-ground gunite 16 x 30 13,000 gal. Full screen enclosure. 120 sq ft. Filter cartridge, 1-1/2 HP pump. Master Pools In-floor cleaner. Taylor K-2006.
  1. Pool Light Question
    By gogolion in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2013, 12:10 PM
  2. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 10:04 PM
  3. Another Light Question
    By AmigaDude in forum Pool Equipment & Operations
    Last Post: 08-29-2011, 09:00 PM
  4. Assembly question on SAM light
    By mshumack in forum In-Ground Pool Construction and Repair
    Last Post: 07-05-2007, 08:51 AM
  5. Led Light Question
    By DONNIE in forum Pool Equipment & Operations
    Last Post: 07-28-2006, 07:20 AM
