Thread: would like to make you aware
    Jun 2013
    us
    Default would like to make you aware
    I recently played around with the dosage calculator. I would like to point out an error. one of the calculations said 1.2cups of bleach and the tablespoon equivalent was 14.4. As a person who has been in food service for 20 years - I believe there are 16 tablespoons in a cup therefore that tablespoon equivalent should be a little more than 16.
    Default Re: would like to make you aware
    What dosage calculator are you referring to? Yes, there are 8 fluid ounces in a cup and 2 tablespoons per fluid ounce so 16 fluid ounces in a cup. 1.2 cups would be 19.2 fluid ounces.
  1. Be aware of 101 bleach
    By shub_31 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-29-2011, 07:54 PM
  2. Just need to make sure....
    By pettinej in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-07-2008, 11:11 PM
  3. Make sure I have this right - TA and CH
    By Trimom in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2007, 04:37 PM
  4. Make sure I got this right...
    By steveinaz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2006, 02:52 PM
  5. When to make Chlorine?
    By Karin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2006, 03:19 PM
