Thread: CYA adjustment
    Jun 2013
    Sand Springs, Oklahoma
    Unhappy CYA adjustment
    Hi,
    I am trying to follow the instructions for how to clean up a green pool in the post titled - Turning Your Green Swamp Back into a Sparkling Oasis.
    I bought the HTH test kit and just did the CYA test. When I shook the water for a little more than 30 seconds it never clouded up at all! Then when I poured it into the black dot viewer the black dot never disappeared. I stupidly poured it all down the drain. I then read a lot more about the CYA test and found out I could have reused that water/solution and did the test a few more times. Anyway, from what I've read I have a CYA reading of zero. I am pretty sure it really is zero because I have never added CYA (conditioner), diclor or trichlor as I have always used Pristine Blue products and hypo chlor shock in the past. This little HTH test only gives you enough chemicals for 2 CYA tests so I hate to blow the second one...
    When I enter my information on the pool calculator it shows that to raise my CYA to 30 (as level to try for according to the algae post instructions) I should add 115 oz. (by weight). I'm afraid to do this. Also, the directions say to add it to a sock and put it in my skimmer. 115 oz. sure won't fit in a sock...
    This is what information I put in the calculator -
    pool gallons - 28,800 (33' round 4.5" AG pool)
    CYA now 0, CYA goal 30
    Could it possibly be right that I need to add that much CYA?
    Thanks in advance for any advice!
    Default Re: CYA adjustment
    That is about the right amount of CYA to get to 30ppm. Do it a couple of lbs at a time. Another way is to put the sock in front of a return jet. Give the sock a squeeze every now and then to help it dissolve faster. When the sock is empty, add more until you get it all dissolved.
  1. Increment of PH adjustment Question
    By goldslinger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-20-2011, 09:15 PM
  2. Pool Chemicals adjustment
    By tfk614 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2011, 10:42 PM
  3. Frequency of pH Adjustment
    By jereece in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-05-2006, 03:45 PM
  4. Doughboy eyeball adjustment
    By prh129 in forum Pool Equipment & Operations
    Last Post: 05-03-2006, 01:44 PM
