Hi,
I am trying to follow the instructions for how to clean up a green pool in the post titled - Turning Your Green Swamp Back into a Sparkling Oasis.
I bought the HTH test kit and just did the CYA test. When I shook the water for a little more than 30 seconds it never clouded up at all! Then when I poured it into the black dot viewer the black dot never disappeared. I stupidly poured it all down the drain. I then read a lot more about the CYA test and found out I could have reused that water/solution and did the test a few more times. Anyway, from what I've read I have a CYA reading of zero. I am pretty sure it really is zero because I have never added CYA (conditioner), diclor or trichlor as I have always used Pristine Blue products and hypo chlor shock in the past. This little HTH test only gives you enough chemicals for 2 CYA tests so I hate to blow the second one...
When I enter my information on the pool calculator it shows that to raise my CYA to 30 (as level to try for according to the algae post instructions) I should add 115 oz. (by weight). I'm afraid to do this. Also, the directions say to add it to a sock and put it in my skimmer. 115 oz. sure won't fit in a sock...
This is what information I put in the calculator -
pool gallons - 28,800 (33' round 4.5" AG pool)
CYA now 0, CYA goal 30
Could it possibly be right that I need to add that much CYA?
Thanks in advance for any advice!
