Hi,
I have been fighting mustard algae all season so far. First time with this stuff and it is relentless. I just have a little, here and there on the bottom. Vacuuming to waste, and it comes back. I have kept my pool at shock levels for over 2 weeks, and it is still there. It is a vinyl liner, IG pool, with only grocery store chemicals, as Ben recommends here.
What is the next safest step for me. Do I have to add a copper algaecide? What are the ramifications of that? I hate adding anything other than what Ben recommends.
I don't want to fight this all summer, and need a solution that will not mess up my water chemisty.
Please help if you have any suggestions to keep me from messing up what I have worked so hard to do (Ben's method only) since my liner was replaced 2 seasons ago.
I don't want to jump the gun and regret something!
Thanks,
John
"Mustard Algae" is probably the MOST misdiagnosed form of algae. Mustard algae is a chlorine-resistant form of green algae (yellow-green to brown in color) typically found in sunbelt areas. It often resembles dirt or sand on the bottom or sides of a pool. In our market area (Fairfield county CT), the number of TRUE Mustard Algae cases that we treat can be counted on ONE HAND in most seasons. Mustard Algae has certain characteristics: It can be brushed away very easily, but returns quickly to the same location. Although it usually creates a large Chlorine demand, it has been known to survive in high levels of Chlorine. It is extremely important to remove mustard algae growth from equipment (including the back of underwater lights & ladders).......
