Results 1 to 3 of 3
Thread: Foam pad?
    Jun 2013
    Maine
    Default Foam pad?
    Just wondering if its worth the extra cost to put a foam pad under the liner of my above ground new install? Thanks!
    Jun 2013
    toronto, canada
    Default Re: Foam pad?
    Depends on the feel you want. Usually it's a smoother floor than sand..However, if one of the sheets slip, you can have a nice groove in that area. I sand usually just gets footprint sand gets real hard over time.
    I have always put foam under my pools. It makes the floor much nicer and also gives another layer of protection between the ground and your liner.
  1. Foam Bottom
    By Ltvanloon in forum Above-Ground Pool Construction & Repair
    Last Post: 06-24-2008, 09:51 AM
  2. Why not just use foam rope?
    By cbridges in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-24-2006, 06:55 PM
  3. foam in our pool
    By Karen L in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-05-2006, 02:19 PM
  4. Oh My.. foam everywhere!
    By tamil in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 11:09 PM
  5. Foam Cove
    By kevkline in forum Above-Ground Pool Construction & Repair
    Last Post: 04-14-2006, 01:05 PM
