If you just filled your pool you'll want to get the CYA levels up. Do you have a Taylor kit? Check out this thread that has detailed information on the kits.
hi sorry i know u get this a lot. and i want to say this site is awesome thx
i just put up my new pool what is a 18X48 full it with well water. water looks good
turnd on pump last night, water still looks good today. i test it with my 6-way test kit today
i just did my CH and PH
CH 0
PH 7.5
i add 2 jug of 4.25% of bleach tonight (need help finding 6%+ bleach in Ottawa, Canada) i look in Walmart just had Great Value brand is 4.25%
what should i do now thx a lot for your guys help![]()
18 oval 7K gal Intex-type AG vinyl pool; splash time, a+c cartridge filter; sfs2000 210watts 2.2amps 2000g.p.h pump; 8 hrs; 1. aquarius, test strips just got aquarius, trousse d'analyse dual test kit; well; summer: solar; winter: none; iPhone; PF:17
Yes I have a hth 6-way one, I test for cya guess it's at 0 how much should I put in? Or how do I get it up thx
Check out Ben's Best Guess Chlorine chart, this will give you an idea about why you need CYA and where you should have it. The easiest way to add it would be to make a trip to the pool store and buy some, normally pool stores call it stabilizer. I bought some when I refilled mine and it was around $36 a gallon if I remember correctly. That was the liquid version, though and that's all I've ever used.
Be sure to stick with either bleach or liquid chlorine, as using any stabilized chlorine will just raise your CYA levels and require you to keep your CL higher to be effective.
went to the pool store and look for stabilizer, ask them if they have any in liquid version, but no. just had stabilizer balancer, and it say i need 300g for 10000L i think i have about 25000L in by pool should i start with about 600g and see what the test CYA levels r tomorrow. the guy at the store say put the stabilizer in to a sock into the skimmer, is this how i do it? or do i have to get the liquid version? thx for your help
Both will work, it'll just take longer to dissolve. Like I said I've only used the liquid but I've read on here that's definitely how to use the powdered form. I would really suggest picking up a Taylor test kit, either the K2006 or K2006-C. I got mine from Amazon thru one of the mods links but I don't see the K2006 on Amazon right now, only the K2006-C. Here's the link to the K2006-C. This kit will allow you to test higher CL levels and also test your CYA levels.
If you are using the dry CYA, you will need to wait a week after putting it in for it to show up on your test. Best that you put 75% of what you think you need, then a week later test, then adjust.
Once you have the sock in the skimmer, chlorinate as if you are already at your target CYA level.
FAS-DPD test kit (such as the K-2006) is a must for this method of pool care.
15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
hi allok after 1 week with dry stabilizer here my test with my hth 6-way tester (the K-2006 is on order)
CH 2-4
AL 330
PH 7.8
HA 200
CY 30 (going to add more stabilizer tonight)
what should i do now thx for all your guys hlep![]()
If your Alkalinity is 330 you wanna get that down, A LOT. You want it to be around 80-120. When are you expecting the K2006? If you're using strips to get your readings I'd wait till you get the K2006 and retest everything as the Taylor kit is much more accurate than strips. But if it is indeed that high you'll want to get some muriatic acid to lower it, this will take some time though because the acid will also lower you pH. So you'll have to add acid, aerate to raise pH, add more acid, etc. Until both your pH and TA are in range.
PebbleTec | 25k Gallons | Purex Triton Whisperflo pump | Magnetek Century Centurion 1.5HP | Hayward Pro Series S311SX Sand Filter | Taylor K-2006 kit
16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
