Thread: im lost
    Jun 2013
    georgia
    Default im lost
    i have tried just about everything...... my water was green and i put algeiced in it cleaned my pool completely changed the sand in my filter my ph and chlorine levels r perfect,,,, but when i turn my pump on my pool water gets cloudy.... sry for the spelling thanks lamar
    Default Re: im lost
    Hi, Lamar, and welcome to the Pool Forum!
    We will have to know more information to be able to help.
    For starters, we need to know what kind of pool, the volume, how big your pump. Also exactly what all have you put in your pool, meaning ingredients and not just 'algaecide' or 'shock.'
    Lastly, we will need current water testing numbers taken with a drops-based kit. The kit that we recommend is the Taylor K-2006 or 2006C which you can get through the link in my signature below.
    Repost with this information and somebody here will try and help you!
    (Do a lot of reading here on the forum, especially the stickied threads at the top of each subforum. Until your registration is completed, you will need to log out first to be able to access the rest of the forum, however. Also, read on our sister website www.poolsolutions.com. Lots of good information there as well!)
  1. Lost Parts
    By jhk49 in forum DPD-FAS based testing
    Last Post: 05-06-2012, 07:16 PM
  2. So lost!
    By ratgirl in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2006, 04:33 PM
  3. Totally Lost
    By Coolflee22 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 12:07 AM
  4. Lost prime
    By hunter580 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 05:22 PM
  5. New guy LOST !!!!
    By AE340B in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 03:31 PM
