Re: help with startup plan for 12ft  intex pool
					The Borax is to offset the pH drop caused by the dichlor - so add Borax with every dichlor addition regardless of the reason for adding dichlor.
To move from the Intex startup plan to regular maintenance, I'd suggest that you learn the BBB poolcare method taught here - Start by reading the guides and tips on poolsolutions.com and the stickies in the treatment and testing forums here (you probably need to log out to see them).  You will need to purchase a Taylor K-2006 or K-2006C to follow this method successfully. If you buy it through the links in this thread the Poolforum get a few shekels to keep the lights on.
You have time - the Intex plan will keep your pool safe while you figure out the rest.
Welcome, Congrats, Good luck, and You can do it - it's easier than it seems.
