Closed Thread
Thread: What are those valves good for anyway?
    Ontario, Canada
    Default What are those valves good for anyway?
    My setup:
    Pool ---> pump---> sandfilter--->Jandy SWG cell--->back to pool.
    Should I have any ball valves in this setup, and why?
    I.G. Vinyl Pool 12' by 24' approx 10,000 gal, Hayward Sand Filter, 3/4 HP Hayward Super Pump, Hayward Aqua Rite Salt Generator, T-15 Cell.
    Connecticut.
    Default Re: What are those valves good for anyway?
    If you have more than one suction inlet and/or more than one return outlet, the valves are good if you want to be able to concentrate the suction to one inlet (in my case I have a main drain and 1 skimmer.....for vacuuming, I dont need the main drain so I turn the valve more towards the skimmer to provide more suction there and less at the drain). I havent found a really great use for being able to close off a return, other than when one breaks (like mine did last year), I was able to at least slow down the leak by turning the valve a little towards the working return (dont want to close down one return completely or you risk the piping not being able to handle all the pressure going to the remaining return).
    Basically it looks like valves add a little flexibility in how your system works. If you dont have multiple inlets and returns, they might not be as useful for you. Personally, Im glad I have at least the inlet valve, because it makes vacuuming more effective. Not sure how close a ball valve could be put near your SWG if you wanted one on the output, Id ask the SWG manufacture if you were interested.
    -Chris
Closed Thread
  1. Need help identifying valves and pipes...
    By whoda in forum Pool Equipment & Operations
    Last Post: 05-13-2012, 09:27 AM
  2. Suppliers of 2 and 3 Way Ball Valves ?
    By blue_steel in forum Pool Equipment & Operations
    Last Post: 04-25-2007, 08:21 PM
  3. One-Way Winter Pool Valves
    By KirstenHW in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-07-2006, 11:38 AM
  4. Operating Valves
    By Simmons99 in forum Pool Equipment & Operations
    Last Post: 08-23-2006, 10:06 AM
  5. Truning the Valves when the pump is on
    By RENOPOOL in forum Pool Equipment & Operations
    Last Post: 05-16-2006, 04:00 PM
