My ph is 7.6 and my alk is 70. If I add baking soda, won't it raise my ph? I was going to add 6 lbs to my 22,000 gal pool. Is this what I should be doing?
Thx!
Paige
Thx!
Paige
In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
Why do you want to add the Baking Soda? To raise TA? 70 is a little low by most standards but if the pH is stable, I'd leave it alone.
K I won't add anything. Just thought the alk should be a min of 80
Thank you for your feedback!
As long as your pH is pretty stable, an alk of 70 is close enough.
If ch and ph are good wont the rest fall in line?
