Thread: Heater with intend pool
    Jun 2013
    Canada
    Default Heater with intend pool
    Hi there pool forum
    Anyone here have an intex type pool (soft sides with frame) and successfully used a pool heater. Our swimming season here is pretty short which is why we have decided intex pool instead of the work/cost of inground pool but even so I think a heater would be a good idea
    Jul 2012
    Mexico, Missouri
    Default Re: Heater with intend pool
    Like you, I have an Intex pool.
    As a season extender, I built my own wood fired heater. Not all that efficient, but it does work.
    One caveat with mine, though, is that I have to keep a very close eye on my pH. If I let it get too far from 7.2 - 7.6, I could easily introduce copper from the pipes into my pool water.
    If you have the means to purchase a heater and pay for the fuel for it, yes you can heat your Intex pool.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2013
    Canada
    thank you! we have found a used gas heater about 2 hrs away on kijiji for $300. Thinking that might be the way to go
    We have ng plumbed to our deck, but that deck is raised quite abit so will have to have pipe fitter come and extend it somehow.. man no matter which way you go, having a pool is gonna cost big $$ LOL
    Jul 2012
    Mexico, Missouri
    Quote Originally Posted by kshuf View Post
    True enough for buying, installing etc. However, if you follow the advise from the experts here, maintenance of your pool can really be close to pennies per day....OOPS, I forgot, Canada got rid of their pennies....
    Enjoy your pool!
    Do read the stickies here before filling your pool.
    Consider also finding a source for a FAS-DPD test kit for testing your water. Yes it will probably seem like a costly item, however you will save that much and more by avoiding costly problems with the chemistry of your pool. There are several threads here about test kits, look them up and read through them.
    Concerning the test kits: I am curious if the components of these good kits are also included in the problems with importing the kits. Could a person not order the full kit, just the individual parts of it and get by with this? or would that also cause problems?
  1. Pool Heater
    By tippywanknobi in forum Pool Equipment & Operations
    Last Post: 12-05-2012, 04:23 PM
  2. pool heater ?
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-03-2008, 08:30 AM
  3. I need a pool heater!
    By ds_girl in forum Pool Equipment & Operations
    Last Post: 02-01-2007, 09:57 PM
  4. best pool heater there has to be one
    By criis in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 09:52 AM
  5. Pool Heater
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 12:24 PM
