Results 1 to 4 of 4
Thread: pool filtration
    Jun 2013
    usa
    Default pool filtration
    hello everyone,
    i am new to the forum but need serious help...i recently opened my pool after 4 years. i got a new pump and started the shock process. everything was going great until i started to vacuum the bottom. so i thought i clogged the pipe from skimmer to pump but blew that out and it bubbled like crazy in the skimmer. my problem is the pump is running but not pulling new water from skimmer??? what can i do to figure out the problem?
    Jun 2013
    usa
    Default Pump not pulling water from skimmer
    My pump is no longer pulling water from the skimmer. What can be the problem?
    Default Re: Pump not pulling water from skimmer
    membership upgraded.
  1. UV Pool Water Filtration
    By Pibster in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-25-2012, 01:18 PM
  2. Filtration / Run Time...
    By The Crow in forum Pool Equipment & Operations
    Last Post: 04-15-2012, 10:57 PM
  3. Baquapur Filtration System
    By DEBKNTX in forum Above-Ground Pool Construction & Repair
    Last Post: 05-28-2010, 07:52 AM
  4. No filtration yet but here are the numbers
    By csevel in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-05-2007, 08:47 PM
