Thread: BBB method?
    Jun 2013
    USA
    Default BBB method?
    What is the BBB method for pool chemicals?
    Default Re: BBB method?
    BBB stands for bleach, borax and baking soda. But, that is kind of misleading because using the BBB method doesn't mean only using those three things. Basically, it means using the least amount of things that a pool needs and doing so inexpensively. Do a lot of reading here on the forum. Until your registration is completed, you'll need to log out to be able to see the rest of the forum. Also read on our sister website, www.poolsolutions.com. Lots of good information there as well. Then, come back if you have more questions.
    Welcome to the Pool Forum!
  1. What's the BBB method?
    By PoolDoc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-25-2011, 10:16 PM
  2. New to BBB Method ... 100 CYA
    By tabjraxa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2009, 11:47 PM
  3. BBB Method - what is it??
    By lovedisney in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 11:21 AM
  4. BBB Method
    By fritochiprt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2006, 06:46 PM
  5. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:34 PM
