My 24’ AG pool has been up and running for 3 weeks now with a Waterco T600 sand filter, 2hp 2 speed Speck pump and Pool Frog system. I've been doing research on chemical prices when I ran across this Forum. I have found references on Google searches that say I can put 3" Trichlor Tablets inside the Frog unit and that the flow controller can be used to set the chlorine. Is this true? So I should pull out the mineral pac and run it with the Bac Pacs till they are used up? I have a Taylor test kit on order and use a cheap OTO test kit and test strips for now. I also see that the Trichlor Tablets will raise my CYA level too high after a while. I hope before that happens I will have switched over to the BBB method. I also have to convince my wife that this will work. She is used to having a pool but not doing it the BBB way. She also thinks the frog supplies are way overpriced and has already yelled at our salesman after his offer of 3% discount on all supplies. She bought a floater and Wal-Mart 3” Trichlor tablets instead.
