How did you get those numbers? What are the ingredients in the fresh and clear oxidizing shock? Don't add anything else to your pool right now except chlorine. If your CYA reading is correct, then you can either use bleach for your source of chlorine and add some CYA separately or you can use dichlor which will add chlorine and CYA at the same time. If you decide to use dichlor, get it from Sam's. Most other places do not sell plain dichlor but instead sell stuff that has other ingredients that you do not want.
Welcome to the Pool Forum!
