Results 11 to 18 of 18
Thread: Test Results - Cloudy Water
    Swansboro, NC, USA.
    Thumbs down Re: Test Results - Cloudy Water
    As of last night the chloine levels were still holding which had been more than 24 hours...This morning when I tested it was back down to 0!!!!!!!! I just added more bleach. The Ph is finally good but I guess that'll change now that I've added bleach! The water is still cloudy even when the bleach held for 24 hours. Diver Dave should be here any time now to start cleaning the bottom and maybe have better water circulation.
    Any suggestions while I wait on what I should do?
    Thanks!
    Default Re: Test Results - Cloudy Water
    Keep hitting it with bleach until it clears.
    The addition of bleach doesn't necessarily mean that your pH will rise--it does in some pools but not all. Even if it does, it's an easy fix to add a little muriatic acid to bring it back down.
    Illinois
    Question Re: Test Results - Cloudy Water
    I'm reading this thread because I, too, have cloudy water and the reasons seem similar to quenterry0. There was a question in there about white film/foam on the surface of the water. I have that too and I don't know if anyone got a chance to respond to that. What is it? I have been following the bleach, borax, baking soda and muriatic acid plan, but with no luck. My ph levels are good this morning, the chlorine levels are a little low so I'll add some bleach. I have been filtering 24/7 since I opened in the middle of May. The cloudy water has not changed at all in 5 days. Ben's test is on its way ( I read somewhere that it's going to be sent out on Tuesday - yea!). Could there be something wrong with my filter (Hayward-sand)? I just don't remember ever seeing foam - almost bubble like - stuff at the top of my pool. Thanks for any help.
    poolbuoy is offline Registered+ Thread Analyst poolbuoy 0
    sturbridge,mass.
    Did you use any Algaecide?
  6. #16
    Swansboro, NC, USA.
    Cool Re: Test Results - Cloudy Water
    mine wasn't bubbly at all just little flake like things??
    My cloudy water never went away - it was a nice blue color but very cloudy! I couldn't see the bottom at all to know where to scrub/vacuum. Finally I added clarifier and my pool is CRYSTAL CLEAR!!!!!!!!
    my next problem I'm trying to figure out - I bought this sand filter used from someone last year - they only had it 3 months and got rid of the pool. I filled it with 50lbs of sand b/c it didn't say on it how much to add and when I dumped the old sand out it looked like the same amount as the 50lb bag. Well it seemed like it was clearing my dead algea so I added another 50lb bag and I think I added too much...I have a pile of sand sitting in the center of the pool. I'm going to try to vacuum to waste and hope it doesn't make it cloudy again my stirring up all the sand.
    Good Luck to you!!
  7. #17
    Illinois
    In response to poolbuoy - no I did not use any Algaecide? I thought you should only use chlorine to kill the algae. My pool is starting to change for the better as I desperatly needed CYA. Now the chlorine is holding and the color is looking much better.
    My new problem is similar to the last part of this thread. Sand in the water by the return jets. A couple of weeks ago, it was just a little sand. Now I've got at least a cup of sand by all three return jets in the pool. Clearly something wrong with the filter (Jacuzzi - ST24) - but what? How can I test where the problem might be?
    I posted this question under the Pool equipment section, but no answers so far.
  8. #18
    I believe that one common problem that has occurred when you see sand blowing back into your pool is that one or more of the laterals may be broken, but to check for that you're going to have to empty the filter again.
  1. Water cloudy, have test results
    By sbillingsley in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-01-2012, 03:07 PM
  2. Test results are good but water is cloudy
    By Crispyc21 in forum Dealing with Algae & Slime
    Last Post: 09-14-2006, 11:56 AM
  3. Cloudy Water - New ps234 kit results
    By szampino in forum DPD-FAS based testing
    Last Post: 08-09-2006, 09:35 PM
  4. Test results - bluish cloudy pool
    By 4KidsSwim in forum DPD-FAS based testing
    Last Post: 08-05-2006, 12:36 AM
  5. Help with test results and cloudy water
    By superjet in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-10-2006, 01:05 AM
