How does your water look? Phosphates typically cause no problem but are a thing that pool stores try to sell remedies for. Continue your plan to use trichlor for a bit until you get your CYA up some but keep an eye on the pH since trichlor is very acidic. Keep your chlorine at the appropriate levels based on your CYA readings (see the Best Guess Chlorine Chart in my signature below) and you should be fine.
Welcome to the Pool Forum!
