Thread: CYA Correction factor for Total Alkalinity
    May 2013
    Maryland
    Default CYA Correction factor for Total Alkalinity
    In the booklet that came with my Taylor 2006C there is a section that advises applying a correction factor of .33-.35 to the measured TA value if there is adequate CYA present in the water. Currently my TA is reading 200, is it safe to consider my actual TA is 200 - (200 x .33), ie 134? Thanks, Mike
    Default Re: CYA Correction factor for Total Alkalinity
    The multiplier is for the CYA level, not the TA level that you were doing. So if your CYA is 50 ppm, for example, then your adjusted TA is 200 - (50 x .33) = 183.5. However, if you use The Pool Calculator, then these calculations are done for you automatically and it will also account for salt and borates levels which the watergram does not do.
    May 2013
    Maryland
    Thanks for the clarification!
  1. Total Alkalinity at 150
    By Chuckles76 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-09-2013, 11:35 AM
  2. Total Alkalinity=0, yes zero!
    By myLABSpool in forum Dealing with Alkalinity and Calcium
    Last Post: 06-03-2012, 01:51 PM
  3. Total alkalinity
    By jksmart in forum Dealing with Alkalinity and Calcium
    Last Post: 07-12-2011, 10:09 PM
  4. Alkalinity correction for high CYA
    By nater in forum Dealing with Alkalinity and Calcium
    Last Post: 07-20-2006, 12:40 PM
  5. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
