Results 1 to 10 of 12
Thread: Pool Pump Makes Strange/Loud Noise
    Default Pool Pump Makes Strange/Loud Noise Updated W/ Video
    That My Pump, It makes this loud noise, its strang, i look at the fan or where the water gose into it, its spinning it is also still pumping so im still running it but its makeing this werid noise and its loud, ill see if i can get a video of it later.
    any help?
    Indiana.
    Default Re: Pool Pump Makes Strange/Loud Noise
    Does it sound anything like a washing machine? That is typical of trouble priming or an inlet restriction.
    To be honest i dont know what it sounds like lol, it's not a humming sound more like a grinding noise kinda, ill see if i get a video later
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    My Last Pump Sounded Like Generator Running And I Bet It Kept My Neigborsfrom Sleeping But That Thing Kept Working So I Kept Them Up Every Night Until One Day I Shut It Off And It Would Not Come Back On Because The Fan Finally Locked Up On It. I Never Knew What The Problem Was But It Would Also Get Hot After Running Awhile So I Would Turn It Off And Pour Water On It Concerned It Might Cause A Problem But I Ran It Alot Before I Bought A New One . Just Be Careful If It Is Getting Hot While Running .
    Morris, IL
    I would say that the grinding indicates that it is going to fail, you can either buy a new one, or use it until it fries itself, at which point you have to buy a new one. That is probably what I would do, but I like my money.
    I like my money to, anyone else have an ideA?
    Downingtown, PA
    Could be the bearings, when they go you will hear a screeching or whinning noise. I guess it is possible it could be a "grinding" noise as well. If your mechanically minded take it apart and check the bearings. If not, evaluate the cost of servicing the unit against running it into the ground. Could be something entirely different as well :-)
    **Could not watch video so my comments may be off**
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    48 Sq Ft Hayward D.E. Filter (2003)
    1.5 hp Hayward Super Pump (2006)
    Aight ill check, i dont really want to get it service cause this is not even a year old, anyone else have an idea?
    Morris, IL
    Tear it apart and look at it. Or else let it be, if you can take it apart, there may be something broken off in there that just needs to get removed, like a broken piece of plastic from a gear or something. Don't damage any gaskets or O-Rings in the process, if you aren't mechanically inclined and don't have any self confidence then leave it alone.
  1. Loud Pump
    By vchavez in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2009, 01:21 PM
  2. Pump making loud buzzing noise
    By Islander2C in forum Pool Equipment & Operations
    Last Post: 06-18-2007, 09:41 AM
  3. Loud Pump Noise?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2007, 08:39 AM
  4. HELP -- LOUD Pump
    By wrinkleigh in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 02:46 PM
  5. pump very loud
    By sunofthebeach in forum Pool Equipment & Operations
    Last Post: 05-09-2006, 01:54 PM
