Just opened up the pool, I have a 18' round ag pool. I just put about 12" of water into the pool. I tested the CYA and it's lower than 30. I use bleach to shock but a floater to chlorinate regularly and usually I have a high CYA level and keep my chlorine levels around 10pm.
My ? is should I raise the CYA with stabilizer since I use trichlor pucks and eventually the pucks will do that for me.
Also I've read many threads and there are different thoughs on what chemical to adjust first. I just shocked and then I'm going to concentrate on Alk and then PH because I know Alk can affect PH...is that correct?
