Thread: Understood about calcium and vinyl, but fiberglass????
    May 2013
    Concord,ca
    Default Understood about calcium and vinyl, but fiberglass????
    I understand calcium hardness test is not necssary for vinyl, but does fiberglass need testing?
    Default Re: Understood about calcium and vinyl, but fiberglass????
    It depends on whether the fiberglass uses a calcium carbonate gelcoat. You could use some CH for safety -- say 150 ppm.
    May 2013
    Concord,ca
    That's xactly what I will do. Thanks to u C. Geek
    I did what you said didn't realize that stuff gets hot!!!
  1. Fiberglass or Vinyl liner
    By Beesmom in forum In-Ground Pool Construction and Repair
    Last Post: 03-27-2012, 02:43 AM
  2. Calcium & Vinyl Pools
    By Cav2473 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-09-2011, 11:17 PM
  3. Calcium hardness and fiberglass pools
    By aguaguy in forum Dealing with Alkalinity and Calcium
    Last Post: 05-13-2008, 04:17 AM
  4. Vinyl Pool and Calcium
    By iwannapool in forum Dealing with Alkalinity and Calcium
    Last Post: 05-30-2007, 09:49 AM
  5. Calcium hardness and fiberglass pool
    Last Post: 07-30-2006, 05:35 PM
