Thread: First Post - Pool Foams when Adding Shock
    May 2013
    Virginia
    Default First Post - Pool Foams when Adding Shock
    30K gal, inground gunnite pool. Still shocking to bring CL level up to specs. Pool foams when shock is added. How to proceed?
    Default Re: First Post - Pool Foams when Adding Shock
    What all have you added to the pool --- meaning ingredients and not just product names. It sounds like you might have used some type of algaecide as some of them foam up in the pool. Also, what type of filter do you have and what size pump?
    Welcome to the Pool Forum!
  1. First Post - SWCG Values Pool vs. Spa
    By NeilH in forum --cleanup--
    Last Post: 05-30-2013, 04:28 PM
  2. Green pool still..after adding lots of shock
    By mom41 in forum Dealing with Algae & Slime
    Last Post: 07-12-2012, 06:39 PM
  3. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  4. Water turned green after adding shock treatment
    By NowhereMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2006, 12:25 PM
