Results 11 to 13 of 13
Thread: Opened for first time with old loop loc mesh cover green swamp
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: Opened for first time with old loop loc mesh cover green swamp
    My advice to you is this.....read all the stickys in this forum and take the time to really understand the chemistry of a pool and how each number affects the other. Once you understand that, just follow the BBB method. Get a good test kit (Taylor 2006c) and whack away with the chlorine. It's simple but difficult at the same time until you understand the process.
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    I too have a loop-loc mesh cover, this is my 2nd season with it. My pool has been a swamp both times I opened it. Previously I had a regular solid winter cover, held down by water bags. I got tired of pumping off the cover, and cleaning off the leaves. That's why I went with the all mesh cover. Do not replace your old cover with an all mesh cover. There are 2 other loop-locs you can buy, one has a couple of mesh panels that let water through, the other is a solid cover with a pump. Either of these will prevent your pool from turning into a swamp over the winter.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
  1. Please help with choosing Loop Loc cover
    By TomC in forum Pool Equipment & Operations
    Last Post: 08-10-2011, 08:30 AM
  2. Just pulled cover off.. green swamp water
    By slade8200 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-18-2011, 05:59 PM
  3. Solid Loop-Loc. With or without center mesh
    By ChristopherS64 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-10-2006, 12:03 PM
  4. How to store mesh loop-loc cover?
    By MykeSS in forum Pool Equipment & Operations
    Last Post: 05-10-2006, 08:02 AM
  5. Loop Lock Cover
    By donfranko in forum Pool Equipment & Operations
    Last Post: 04-03-2006, 02:26 PM
