Thread: starting new any advice
    Jul 2011
    Wantagh
    Default starting new any advice
    I had my liner harpooned during sandy and my replacement is due any day. The pool is 16'x36' inground with an 8' deep end so I guess around 36,000 gal, the tap water used to fill the pool has a PH of 7.3 and a TA of 40. I tried the BBB method and followed the advice I was given on this site and it worked well for me. This time I went for the all black liner I know about the depth perception problem is there anything else to look out for? Anything to do/add during filling? I assume everything in the BBB method will be the same .Also I want an automatic vacum from my skimmer what do you think of these and what about the $100 ebay ones? Last question(for now) with a black liner should the solar cover be on or off(day time) when the pool is not being used and what color is best for a solar cover? Thank you
    inground rectangular pool 16' x 36' 8' deep end 26,000 gallons black vinyl liner
    BigDave's Avatar
    Default Re: starting new any advice
    Be sure to add bleach while filling - you wouldn't want to start with a swamp.
    After it's full you may want to bring up your TA a little with baking soda. The pH will come up a little with the baking soda and the bleach will raise it a little too.
    All black - sounds dramatic. It might bleach more easily than light colors and light spots will stand out more - be sure to mix the chlorine well.
    Don't know about the auto vacs.
    A clear cover might let you catch more light in the liner - I like blue - it just looks right for the pool.
  1. Starting over
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 08-02-2012, 01:54 PM
  2. Starting Over
    By shawnw in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-30-2012, 03:33 PM
  3. starting old pool
    By csc138 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-26-2012, 03:44 PM
  4. Starting from Scratch
    By anixon7 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2012, 03:50 PM
