Thread: Intex pool pump upgrade
    Jun 2011
    Oklahoma
    Default Intex pool pump upgrade
    I have a Intex ultra frame 20x48. I am currently using the pump that came with it which is an Intex Krystal Clear 635t 1500 gph with a size A filter(I do have the better filters that can be cleaned and reused). I have been wanting to replace the pump as I don't feel like its getting the circulation the pool needs to keep clean. I have seen it posted you don't want to get too big of a pump and I'm not sure what I can get that will hook up to the pool. Any advice would be appreciated!!
    20' x 48" Intex round Ultra AGP ~8800 gallons -- Intex krystal clear 635t 1500gph; PF: 13
    Jun 2012
    Texas
    Default Re: Intex pool pump upgrade
    I just installed the Intex 2650 on my pool that is the same size and I am amazed at the difference. This is a sand filter also and seems to clean a lot better than the original pump and filter.
    20' round 8.8K gal Intex AG vinyl pool; Intex saltwater generator; cartridge filter; pump; hrs; Local pool supply company; City;PF:14
  1. Intex pump upgrade
    By costo in forum Intex-type Pool Setup & Operations
    Last Post: 06-22-2013, 05:42 PM
  2. Intex AGP pump upgrade advice needed....
    By sgtreadwell79 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-19-2013, 04:56 PM
  3. Intex pool filter and pump upgrade options/considertions
    By SafetyBob in forum Intex-type Pool Setup & Operations
    Last Post: 05-12-2012, 06:52 PM
  4. upgrade 20x4 intex?
    By jdsapp in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-24-2011, 08:05 AM
  5. Can I upgrade from the Hayward EC-65 to the EC-75 using the same pump?
    By bobjersey in forum Pool Equipment & Operations
    Last Post: 06-09-2010, 08:06 PM
