Results 1 to 10 of 10
Thread: Should I change my Pump Impeller or buy a Variable Speed Pump?
    Oct 2012
    Alabama, USA
    Default Re: Should I change my Pump Impeller or buy a Variable Speed Pump?
    Answers:
    What is your current filter pressure?
    -Current pressure is 18 lbs. When it's clean the pressure is 14 lbs.
    How high is the filter gauge relative to the pool water level?
    -50"
    Number and length of suction lines from the pool to the pump?
    -Two lines which come together as one somewhere underground: from skimmer to pump is 12.5' and from drain to pump is 22'
    I doubt the pump is over sized, it is one of the smallest pumps on the market. If you have sand blowing into the pool, it could be broken lateral. That is the most common issue with sand filters.
    -I have completely replaced all the components to sand filter, so I have ruled out a problem lateral. The only thing not new is the tank.
    Thanks, DBR
    21000 gal IG - 16x32 Vinyl Liner - Hayward 1HP pump - Hayward S244T Sand filter - Booster pump w/Polaris 280 cleaner - Pentair Rainbow 320 Chlorine Feeder - Taylor Test Kit K-2006C - Borate 50ppm - Salt 2400ppm - BBB all the way!!
    mas985's Avatar
    Pleasanton, CA
    The pressure seems a bit high for that setup so that might have something to do with it. Does the pressure gauge go to zero when the pump shuts off?
    Assuming the gauge is correct, the pump's operating point is around 42 GPM @ 54' of head. The 244T is a 3.1 sq-ft filter and it has a design flow rate of 62 GPM so the flow rate from the pump is fine. I would focus on the filter. Given the pressure, something is still not right.
    Mark
    Oct 2012
    Alabama, USA
    Yes, the gauge goes to zero when the pump is shut off. I replaced the pressure gauge when I rebuilt the filter. Is it possible that the wet end has the impeller for a 1.5 hp pump?
    Are you saying my setup has a 54' head?
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by Dead Beaver Ranch View Post
    Not unless the motor was up sized as well. Up sizing the impeller without up sizing the motor will overload the motor and trip the thermal limiter switch.
    Yes, that is my best estimate based upon the filter pressure and the suction side plumbing layout.
    Mark
    Oct 2012
    Alabama, USA
    So it looks like I should leave well enough alone as far as the pump goes. Is the pressure I am seeing at my filter what you would expect? If not, is it higher or lower than you would expect? Thanks again.
    mas985's Avatar
    Pleasanton, CA
    As I posted earlier, the pressure seems to be a bit high which means that there is more head loss in the return plumbing than would normally be expected for that setup. It could be the filter or anything after the filter.
    Mark
    May 2013
    S. California
    mas,
    Would you recommend him tapping into the system in a few different points to determine where the back pressure is? Maybe one between the filter and heater and then one after the heater.
    skeeter
  1. Vacuum with variable speed pump
    By ronpbak in forum --cleanup--
    Last Post: 10-04-2012, 05:46 PM
  2. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  3. what speed on a variable pump?
    By bomberchamp in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 11:53 AM
  4. variable speed pump
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 09:18 AM
  5. Variable speed pump upgrade
    By kmh in forum Pool Equipment & Operations
    Last Post: 10-17-2011, 08:33 AM
