Results 1 to 1 of 1
Thread: yellow-brownish stains
    Default yellow-brownish stains
    opened my pool as i've done for ten years shock as usual water became green . my test were.TH-100 TC-10 FC-10PH-6.8 TA-40 CA-0-30 pump ran 2 days ,got my water tested at the store ,water was basically the same saturation index. -1 TDS 200 CYA- not tested TC-8 FC -8 PH-7 demand drops-6 TA-60 Adj.TA 60 TH-150 optimizer= not tested copper- 0Iron. -0.1 Manganese no cloudy- hazy green algae-none black A.-none mustardA.-none Slime mold -no. so the guys says maybe the stains are mustard A. that it grows in the liner???? and my metals aren't high but try pool magnet plus.....then i need 21 lbs. to raise my alkalinity ????
    what Idid was put the required dose of Algae Kill (6 oz.) in . waited and brushed and brushed. to remove the stains... water did get alot better back washing was very yellow . but my stains are still there
    so i'm thinking it is the Algae should i keep putting MORE algae Kill in or maybe shock again Hey between you guys and some comon sense i've handled and fix all prblem in these ten years but these stains got me stumped
  1. salt conversion gave brownish stains
    By JackandJibby in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-20-2011, 09:10 AM
  2. used yellow out before I found you.....
    By hkcon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2011, 03:34 PM
  3. Keeping the Chlorine up and light yellow stains
    By jonnygib in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2007, 12:42 AM
  4. HELP!! Greenish/brownish pool...just filled it!
    By twinsplus1 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-04-2006, 10:29 AM
  5. Brownish-gray stains in vinyl IG pool
    By gumbeaux71 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-22-2006, 01:57 PM
