Closed Thread
Thread: Can't control CHlorine levels..
    Anonymous European in California Guest
    Default Re: Can't control CHlorine levels..
    Tests Today:
    CYA - 0
    FAC - 0
    pH - 7.5
    Alk - 80
    I went back to the 'setup box' we bought from Walmart and it didn't supply any Stabilizing fluid, so I presume this is the problem. Going to go buy some chemicals to raise to 50ppm and then add Chlorine tomorrow morning and see what happens.
    BigDave's Avatar
    You are right that you need stabilizer - chlorine will be very quickly destroyed by the sun without it.
    Ben wrote a fantastic startup guide for pools like yours, find it here: http://www.poolforum.com/pf2/showthread.php?17055-Super-simple-pool-chemistry-recipe-for-Intex-type-pools-start-up-amp-routine-care. I don't know what you've done so far, but reading through it should help. Reading through the stickies here, on the forum and reading through the material on PoolSolutions.com will help alot too.
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Quote Originally Posted by Martin View Post
    Tests Today:
    CYA - 0
    FAC - 0
    pH - 7.5
    Alk - 80
    I raised my CYA last year by using some dichlor powder I got from Leslies. Then went to the BBB method. Good Luck..
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    May 2018: All European users deleted, and any posts by Europeans anonymized to avoid EU GDPR violations.
Closed Thread
  1. Can't keep chlorine levels up
    By cbednara in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2012, 04:53 PM
  2. Low Chlorine Levels
    By rwhitsel in forum Dealing with Algae & Slime
    Last Post: 06-03-2011, 07:15 PM
  3. chlorine levels
    By fhorta in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 06:26 PM
  4. Need Help with Chlorine Levels
    By stateroaddog in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2008, 09:09 PM
  5. Chlorine & pH Control
    By karrde97 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-25-2006, 12:47 PM
