Thread: Filling up a pool with well water, What steps should I take ?
    May 2013
    texas
    Default Filling up a pool with well water, What steps should I take ?
    Hi,
    I am about to fill up a 16 by 48 Intex metal framed pool with well water. I have a game sand filter/pump and a Intex Salt Chlorine Generator . From what I've read this most likely turn the water brown. Is there anything I can do to help with this while I fill it up ? And what steps should I take from the beginning to fix this?
    Thanks,
    Mindy
    BigDave's Avatar
    Default Re: Filling up a pool with well water, What steps should I take ?
    Have you read through http://www.poolforum.com/pf2/forumdi...tex-type-Pools? You may find your answers there.
  1. Filling a small pool with iron well water
    By newbiepool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 05:24 PM
  2. filling 16' donut pool with well water, and chemicals....
    By sewzhmkr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2007, 10:27 PM
  3. Filling pool with Well water without running well dry
    By SissyH in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 04:41 PM
  4. Pool is filling - tap water results.....
    By court475 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2006, 01:51 AM
  5. Filling a pool with Sulfur water...not good.
    By faithfulfrank in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-18-2006, 11:00 AM
