Thread: Should I shock my pool upon opening, even if there is no algae build up?
    Oct 2012
    New Jersey, USA
    Default Should I shock my pool upon opening, even if there is no algae build up?
    Hi. My pool is a 20x40 in-ground with 40,000 gallons of water and a vinyl liner. I'll be opening it on the weekend. When I closed it in October, it was absolutely crystal clear and spotless, and the other day I pulled up a corner on the (solid) cover, and it seems to still be completely clear.
    Considering this, would it be a good idea to use shock to get the chlorine levels up asap, or would standard chlorine/bleach treatment be fine since there is no algae problem?
    Thanks!
    Virginia
    Default Re: Should I shock my pool upon opening, even if there is no algae build up?
    Quote Originally Posted by Racker View Post
    Thanks!
    I always shock to kill/burn off other things that are in there besides algae. My pool is also clear when I open it, but it's obvious from the chlorine consumption after shocking that there are other contaminants that have to be cleared up.
  1. Re-opening pool to Green and Algae
    By rgauthier20420 in forum --cleanup--
    Last Post: 05-24-2013, 01:36 PM
  2. New member- opening with algae
    By ColdCanadianPool in forum Dealing with Algae & Slime
    Last Post: 05-23-2013, 07:48 PM
  3. Does algae ever build up in water lines?
    By bboehm in forum Dealing with Algae & Slime
    Last Post: 04-20-2007, 07:27 PM
  4. Calcium/Scale build up on opening
    By DM in forum Dealing with Alkalinity and Calcium
    Last Post: 05-11-2006, 06:17 PM
  5. Opening With Chlorine, Shock Concentration
    By rossmic in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-20-2006, 04:14 PM
