Thread: position of pool valve( with photos)?
    Default Re: position of pool valve( with photos)?
    No, multi valve is not set to backwash. Its in the filter position. Should the valve be opened or closed? Thanks...
    figured it out. re-installed the eye, position of valve should be closed
    HI!
    Happy spring and the start of a new pool season
    The valve on your 'waste' line is a 'cheat'
    It's used when the spider gasket in the multiport is bad and keeps you from inadvertently draining the pool when running it in filter mode. The proper fix is to replace the spider (or wagon wheel) gasket in the multiport ( part # SP 715 - D). Replacing the gasket will keep the water from being sent to the wrong parts of the system.
    If you need any help or more info, just let me know.
  1. Above Ground Pool Construction Photos
    By gwrace1 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-12-2010, 06:19 PM
  2. Selector Valve Position?
    By colby in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 12:49 AM
  3. backwash position for pentair 2" slide valve?
    By madgame8 in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 01:27 PM
  4. Pool building Photos 1
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 07-07-2006, 08:20 AM
  5. Photos of my DIY gunite pool
    By y0manda in forum In-Ground Pool Construction and Repair
    Last Post: 06-26-2006, 04:28 PM
