I opened my pool yesterday. Everything was fine and I ran it all night. I vacuumed it yesterday and needed to finish that today. The pump basket filled with debris, so I opened it and cleaned it. I noticed the check valve was also full of leaves, etc. so I opened and cleaned it too. Now I can't get water flowing again. The pump is running but won't pull water through. I removed the pump basket lid and check valve and re-seated them several times, and I added water to the pump basket, but I can't get water flowing. If it matters, when I open the pump basket, the inner basket floats (the one you remove for cleaning). There is plenty of water in the pool, the skimmer basket is empty and I didn't change or touch anything else other than cleaning the items above. How long should I have to let the pump run to re-establish suction? What else should I check? Any ideas?
Charlie
