Results 1 to 4 of 4
Thread: Cyanuric Acid Chlorine Conditioner
    Sep 2011
    California
    Default Cyanuric Acid Chlorine Conditioner
    The granulated Cyanuric Acid Chlorine Conditioner I have been using takes forever to dissolve. The last time I cleaned my filter I found a pile of it on the bottom completely undisolved. I have tried putting it in a bucket of hot water but even that doesn't seem to work. My question, Leslie Pools has a liquid Cyanuric Acid Chlorine Conditioner, is that a suitable substitute? Any thoughts would be appreciated. Thanks.
    California
    Default Re: Cyanuric Acid Chlorine Conditioner
    You would usually just put it in a sock or stocking and hang it over a return flow. Or you can put it into a T-shirt in the skimmer if your skimmer has a bypass pipe so that clogging it doesn't cause any problems. Most people do the former sock method; I've done the T-shirt in skimmer method and it all dissolves within 24 hours, often within 12 (with the pump running the entire time). The Instant Pool Water Conditioner you are talking about does dissolve faster, but it's about twice as expensive per CYA ppm.
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
    In other words, if you're willing to pay the premium for liquid CYA, it does work and does disperse faster than dry CYA.
    Sep 2011
    California
    Great suggestion I will try a sock, thanks.
  1. Cyanuric Acid Chlorine Conditioner
    By JohnASmith in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-09-2013, 09:36 PM
  2. No Cyanuric Acid?
    By Strongmad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2012, 12:21 PM
  3. Cyanuric Acid
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2006, 04:30 PM
  4. where to get cyanuric acid?
    By fog80 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-07-2006, 10:22 PM
